RB2011UiAS V 6.18 Issues with Adtran 3884T & OSX/Windows
Ok so here is the issue I am having it’s driving me insane. We currently have a 20MB/s wan connection from XO and they deployed a adtran 3884T gateway. We configured our RB2011 and we can report we have wan connectivity. “so far so good”.
Here is the Major disparity I have discovered. When you run a speed test on speedtest.net to test your wan connectivity speed if your on a Windows based system you get 19MB/s Download and 1 MB/s Upload while on a Apple Macbook you get 19MB/s Upload & Download.
I thought this was odd I brought another router a RB2011UAS-2HnD from my house with a factory reset configuration configured the static ip’s for the wan and the got the same exact result.
I have tried hard coding the ether1-gateway for 100 Full Duplex no change, Queues on and off no change, firewall on and off no change. Any Ideas or suggestions would be immensely helpful.
Thanks Guys
Sadly, many of the overpriced and under-featured WAN providers do love to show that they are living in yesteryear by configuring their Adtran units to 100Mbps/FD. I would make a point of confirming exactly how the interface is configured before making any assumptions about the observed problems.
Yup talked to XO they hard coded it to 100Mbps/FD. Issue stays the same.
And it’s fixed apparently if you have a Adtran fixed to 100 Full Duplex I only works when you connect it to the 10/100 ports on the RB2011.
