I have a very serious problem with installing a 3g modem huawei 660A pcmcia on a rb230.-
When I plug modem in a pcmcia slot I’m having random reboot before modem connect.
When I plug modem in a pci-pcmcia adapter slot the system hangs.
After probing with several linux kernels versions nothing changed, same behavior.
I worked out the first problem by uprading bios version: 1.3.7 to 1.3.8 and it worket by 2 hours. Now I have another very hard porblem:
I was connected to the modem for a 2 hours and then I rebooted system to test it. But after a minutes system hangs and all leds is blinking.
I rebooted and I get:
48 VCC Output 0.5 A
24 VCC Output 1.2 A
20 VCC Output 3.4 A
24 VCC Output 6 A
and nothing changed.
now I suspect that it’s a signal problem.
because I moved to another location with best performance signal strenght and random reboot disapeared (after ugrade bios).
The situation is: modem 3g installed on a rb230 sometimes reboot with poor signal strenght.
Next step maybe I would get a aditional external antenna.
