RB250GS is not resetting , and not working after 1.8
Hi there
I have 5 RB250Gs ,
after uploading the new firmware
one of The devices became unresponsive
when i boot the device , the act led just goes blinking like crazy and i’m unable to access the device
I tried the 2 reset ways with no response ?
Did my switch die :slight_smile: ??
Fast blinking of the ACT led means RB250GS is requesting a firmware file.
You can recover it with reinstallation procedure: http://wiki.mikrotik.com/wiki/SwOS#Reinstall_SwOS_firmware
Thanks for reply .. but unfortunately the switch did not respond to tftp upload
kept blinking like crazy and i waited 10 minutes then rebooted the switch
same crazy blinking syndrome :slight_smile:
TFTP upload should happen in few seconds, it is not worth waiting longer than a minute. :slight_smile:
Perhaps there is a communication problem between router and RB250GS. Check DHCP server configuration and make sure it has “bootp-support=dynamic”.
I’ve made sure of all settings
I also found that dhcp ranges was wrong in the
Wiki explanation and I corrected it
Bootp was enabled and dynamic
Any other suggesdions
