RB250GS Manual
Is there any place that I can download a manual for the RB250GS?
I’m interested in getting one to try, but need to know the basics, like can I get SNMP data per ethernet port, how the VLANs work, etc.
I don’t think you will need a manual. Configuration is pretty intuitive.
The default IP is 192.168.88.1
Just connect to it with a web browser and go through the menus.
There is an SNMP option and a statistics menu with lots of port details so I will assume that you can access these statistics through snmp.
Maybe Normis will confirm that when he returns from holiday.
Tom
Tom,
Do you have any?
If so, have you snmpwalked them?
Alternately, what SNMP details appear in Dude?
Eben
Realy, where is manual?
On the wiki, where the manuals for all other products are.
http://wiki.mikrotik.com/wiki/SwOS
My problem is that it does not pass the Vlan by the switch RB250GS
“BY GOOGLE TRANSLATOR”
Usually when i don’t know the OIDs i snmpwalk the whole MIB. You can also print the interface counters OIDs from the interfaces menu.
