How do i change the default IP address (192.168.88.1) of the 250GS?
I tried changing it on the system tab, but it doesn’t apply.
I cannot access to SWOS if i hook it up to my 750G as its already 192.168.88.1.
Thnx in advance.
Make sure to upgrade to 1.2 (requires manual reboots), then try again.
After the flash process begins..
It will look hung… (Only on 1.1)
Geve it about 1 Min to complete (to be safe I give mine 2 Min)
Then cycle the power..
1.2 fixes the flash issue…
MY 250GS came with 1.0
Tried flashing it with 1.2 but it hung on that page. Gave it 30mins, but still look the same.
Powered cycle the unit and could access the switch anymore.
Tried hard reset but still the same.
Changed the unit today and will try again.
