RB260GS and CRS125-24G-1S IPTV issue
Hello
I have 20 streamers on IPTV application , when I use RB260GS all streams are ok and video fine.
Just when connect CRS125-24G-1S and replace the RB260GS , I got some pixelate on the picture , when I switch it back into 260GS work fine.
I tried on CRS125 disable the firewall and
1-Bride all interface (same issue).
2-Make ether2 master port for all interface (less pixelate).
is there is any way to configure it like 260GS ?
do you have the issue using default configuration??
this is using it as a switch only
Odd… first thing I’d try is upgrading RouterOS, upgrading firmware, and reset configuration with no defaults. Then reset again with defaults or setup master/slave ports accordingly. Have you checked tools > profile when streaming?
Also try setting all ethernets hardware queue type from only-hardware-queue to “default-ethernet” and see if it makes a difference.
remember CRS only supports jumbo frame up to 4k
