Im trying to configure an RB260GS with one vlan.
I need all the Layer 2 MTU I can spare so I just want to add a VLAN ID=10 on the router board 493, then send that traffic to the switch port 2, and when the switch sees the ID=10, sent it out port 4, strip the vlan header. reverse the process for incoming traffic on port 4.
If I send untagged traffic from the router board to port 2, I just want it to switch it as normal to the other ports, but It seems I have to create a vlan ID of 1 on the router board and the switch and use that? That adds the vlan header and I can’t spare the MTU bytes.
How should I set it up?
