RB260GS ONU in GEPON network using SFP (TX=1310nm/RX=1490nm)
Pardon me if I have some information/questions wrong - I am new to this …
We are building a 2,000 to 4,500 client FTTH GEPON network (GEPON - not GPON). I was considerint Adtran or Calix - however I am now taking a serious look at the Mikrotik RB260GS (or something Mikrotik that will support client ONU side NAT) for use as the customer located ONU.
Our plans are to use a maximum of 16-way passive optical splitters and drop down to 8-way splitters for our most distant clients on the fiber PON. This should enable 100+ meg download speeds for everybody at the same time and not encounter network congestion. (FYI I am considering a bank of squid servers to buffer/cache http traffic)
I am guessing that I am going to need about 300 head-end OLTs to talk to the 2,000 to 4,000 client GEPON ONU devices (best guess at this time).
The head-end OLTs will use SFP fiber lazer modules which use wavelengths of TX=1490nm/RX=1310nm.
The client-end ONUs will use SFP fiber lazer modules which use wavelength of TX=1310nm/RX=1490nm.
This way each head-end OLT will be able to send & receive to up to 16 client ONUs through the passive optical splitter PONs.
Many client located ONUs will be close/local (16-way splitters) and some may be up to 24 miles away (thus the reason for 8-way splinnters for the extra db signal)
I am planning to offer triple-play where customers can have (IP-TV, VO-IP and Internet from 5 to 100+ MB download speeds).
Here are my questions:
  • Has anybody got something like this working using Mikrotik as the ONU?
  • What GEPON SFP modules were used in the client ONU and the head-end OLT?
  • Does it work well - and should I also me considering other types of ONUs and OLTs?
  • What SIP devices appear to work well?
  • What else should I be asking or looking at?
Thank you for your input and answers.
Tom Jones (in North Idaho U.S.A.)
Red-Spectrum
Coeur d’Alene Tribe
Have you had any luck tracking down any SFP modules that will work with GEPON?
Small world (dslr)…
I’ve been looking into the same thing for a few weeks. Finisar did make an announcement in sometime last year regarding a SFP E/Gpon module. It was dubbed the “gpon stick”
Here is the announcement and a product link page, although I’m not quite sure if they have finished development or exactly how to get a hold of a few to do testing.
http://www.finisar.com/blogs/lightspeed/category/transceivers/
http://www.quagwire.com/optical-transceivers/pon/finisar-pon-transceivers/
If you guys are able to source further information, please be sure to note.
I checked them out a little bit, but they don’t have much documentation that shows any real specs. I’ll keep digging, but if you find out more before me, be sure to post! :slight_smile:
Mikrotik doesn’t support EPON protocol!
You can try with EPON STICK ONU SFP Transceiver, he has integrated EPON chip.
