Hi, I’m in need to configure ipv6 ACL on a rb260gs in order to change 802.1p priority on some packets.
When I match packet using ethertype 86DD (ipv6) the priority is successfully set, but as soon as I try to use a more specific matching (in my case protocol 17 (udp) and 58 (icmp6) packet are not matched anymore. Same issue if I try to match on destination port.
Are ipv6 acl supported by swos or is it a chip limitation ?
