I am assessing this unit and deliberately locked myself out to test the reset procedure (no, really). Holding down the reset button only gets me to the firmware upgrade mode. I’ve tried to short circuit the board by delicately yet brutally shoving a hex key into the hole on the bottom repeatedly and with an increasing savagery to no avail. I’m currently trying to reinstall the OS using routerOS but it’s not having it. Here are the details on the connected routerboard:
/file
swos-rb260-1.10.lzb .lzb file
address=10.10.10.1/24 disabled=no interface=ether9 network=10.10.10.0
address-pool=test_dhcp_eth9 authoritative=after-2sec-delay bootp-lease-time=forever bootp-support=dynamic disabled=no interface=ether9 lease-time=3d name=test_DHCP_eth9
address=10.10.10.0/24 dhcp-option=“” dns-server=“” gateway=10.10.10.1 ntp-server=“” wins-server=“”
name=test_dhcp_eth9 ranges=10.10.10.50
/ip tftp
allow=yes allow-rollover=no disabled=no ip-addresses=10.10.10.50 read-only=yes real-filename=swos-rb260-1.10.lzb req-filename=“”
/ip dhcp-server lease
10.10.10.50 00:00:00:00:01:01 test_DHCP_eth9
It picks up an IP but the TFTP server process doesn’t record any ‘hits’. Any ideas folks?
