RB260GSP and RouterOS
RB260GSP supports only SwOS.
It has 4 Gbe PoE and one SFP port, so it might be a perfect router for small nodes.
Do you have in roadmap a similar product witsh RouterOS support?
It will be great …
It could be a router if it had enough memory, powerful cpu and interfaces connected to it individually. Look for router if you need a router and don’t look at switches.
check the RB2011iLS-IN or the RB2011UiAS-IN
that gives you the routing and gigabit switch with sfp cage
Yes,
but it is bigger, more expensive and it has no PoE out …
