rb260gsp cannot login
Hello. I have brand new rb260gsp. Lan on pc have 192.168.88.2 addres. I can ping 192.168.88.1, but when i try to log in via any browser i have only Mikrotik SwOS on left upper corner and text loading. whats wrong?
Try:
  • Emptying browser cache
  • A different browser (Firefox)
  • resetting it
Hi! Same problem here, all above didn’t help. I still have MikroTik SwOS startpage with “loading” sign. However switch works properly.
Try unplugging all cables but the one in the port you’re connecting to, reboot it and try to access.
P.S. Latest SwOS is 1.17
Also the same problem here. Tried on multiple workstations with no luck.
Same problem with 1 out of 5 units I ordered…
See this thread /viewtopic.php?f=17&t=113160
I have exactly the same problem, do anybody has found the solution?
I’ve had exactly the same problem with multiple RB260GSPs. VERY ANNOYING.
Hex POE is the solution unfortunately. (Coming from an owner of 2 RB260GSP’s, I’m waiting for mine to die so I can move over onto something with RouterOS)
