Hello
i am looking for simple config for RB260GSP
SFP and Ether1 as Trunk port
Ether2,3,4,5 each one have two Vlan in same time
Vlan for internet
Vlan for VOIP
any help
Hello
Vlan for internet
Vlan for VOIP
any help
WOWO 51 visit and no one know what i am ask
you should read manuals, test and if something will go wrong ask here in forum.
Its not school, and we are not teachers. Use your own brain.
oh thanks zyzelis but if you don’t know how to answer its good if just do like the other don’t answer
also not all smart like you they can do it from the first time
if you have the answer that will be good if you don’t have it just pass the post and don’t say anything
may be yo will see something never like it
You can find the manual here.
http://wiki.mikrotik.com/wiki/SwOS
There is no the “regular” way to create Vlan for VOIP on SWOS
the configuration that you asked is very simple, so i hope, after reading manual, you can handle it. ![]()
if something will not work, post printscreens here, and we will help you…
good luck.
