I see Calibrate on the POE settings on the 260GSP but can not find any explanation of how it functions.
From support ask some question.
The “calibr” allows to manually force the
recalibration, it will ask to disconnect cable and return to auto mode after
webpage refreshing. It is not necessary to use it when the PoE works properly.
