RB260GSP - Possible to make a 6 Port using SFP module?
Hi.
We need a small 6 port POE switch. The RB260GSP looks perfect, except its 5 ports.
I see it has a SFP cage.
Can Mikrotik / someone with knowledge let me know if I can install a 1gbit ether module in the SFP cage and turn this into a 6 port switch?
We do not need POE on this extra port BTW. Just to be able to VLAN it with the existing 5 ports.
Also, will the switching be handled by the same chipset as the 5 onboard ports? Eg: Any performance penalty to running things this way?
Thanks!
did you try to instal the RJ45 SFP module?
Try this: https://mikrotik.com/product/S-RJ01
https://wiki.mikrotik.com/wiki/MikroTik_SFP_module_compatibility_table
We have not purchased anything yet, we wanted to verify on here before buying.
I checked the comparability table, it makes no mention of the CSS106-1G-4P-1S for ANY of the SFP modules.
