RB260GSP switch POE supported voltages
Hi, we are looking for a replacement to the Netonix WS 6 Mini switch as they are becoming harder to find in stock in the UK and as we use a lot of Mikrotik routers and familiar with the OS was wondering if they offered a switch that would replace the WS6
We are looking at the RB260GSP as 4 usable POE ports is all we need really BUT we do need the option to set individual POE power settings on the ports to either 24v or 48v due to what we plug in, i.e. 2 ports maybe 24v and another 48v ( Nano’s and Camera for example ). Can anyone let me know if that possible, from what i know on the routers its either on or off and set via what every power supply you use.
Ports 2-5 can power other PoE capable devices with the same voltage as applied to the unit.
https://i.mt.lv/cdn/product_files/RB260GS_211055.pdf
Yes i understand that but my question was can each port be setup differently
differently ? No … “the same voltage as applied to the unit”
The 260GSP is only 24V.
If you want to use 48V you can use a HEX POE with a 48V adaptor. to get 24V from a 48V input https://connectec.uk/electrical/power-supplies-psu/poe-power-supplies/ubiquiti-ins-3af-i-g-instant-gigabit-passive-poe-48v-to-24v-converter
