RB3011 & 3 RB951G VLANS
Hi Guys,
Can anyone help me here I have my RB3011 set up as CAPSMAN (All working fine) with 3 RB951G’s I wan’t to set up 2 WiFi networks Public and Private and also set the switch ports on each RB951G to Public and Private so Port3 - Private Port4 - Public Port 5 - Trunk
On the RB3011 I also need switch ports Public Private and also Office 1 and Office 2 + Trunk
Is all this possible can anyone point me in the right direction?
Planned diagram attached can anyone help with the config for this or point me in the right direction.
Hello
I’m using 3011 too and would like to get VLANs working on it
Problem is that since more over 1 months Mikrotik support couldnt figure it out what is wrong with port based VLANs on 3011.
My config You will find http://forum.mikrotik.com/t/some-help-with-filter-rules-needed/96097/1
VLANs on trunked port working properly but computer conected directly to ethernet port of 3011 couldn’t act properly
Ping local gateway drops 40-80% and so on
Has any one similar problems with VLANs on 3011?
Regards
SLawek
I have this working now, I have one issue I hope someone can help with.
VLANS are all set up on master port 2
Bridge-local contains ether2 & ether6
All CAPs register and connect and the vlans get the correct ip when connected on ports 2-5
CAPs connected 6-10 register but the don’t don’t get an ip.
If I move the vlans from ether2 to bridge-local interface everything seems to work ok.
But when I do this winbox won’t connect with the MAC address anymore I have to use the ip?
