As far as I can tell, the router just isn't talking with the modem. On the Quick Set page I'm showing no IP address under the Internet section, and the "renew" and "release" buttons have no effect. Whenever I try to ping from the router outside the network I get a "No route to host" error, but I also get it while trying to ping the modem. Everything's running off the stock configuration, and if I connect a machine directly to the modem it functions flawlessly. The setup is > Netgear CM1000v2 > RB3011 > endpoints, including a CAP (but I'll get CAPsMAN sorted another day... having issues there too). Based on past posts, it seems to be a DHCP client issue I think? "ip dhcp-client print" returns:
INTERFACE USE-PEER-DNS ADD-DEFAULT-ROUTE STATUS ADDRESS
0 I ;;; defconf
ether1 yes yes
