Software bonding seems to be working. I have a SFP and a Ethernet port bonded with multiple VLAN interface on it. RB3011 is not replying any ARP requests from devices under CRS317.
My setup:
RB3011 - SFP + Ethernet bond - CRS317
RB3011 has a bonding interface and multiple VLAN interfaces configured, add bonding interface to main bridge and VLAN interfaces to other bridges, all bridges enabled VLAN filtering;
CRS317 used only VLAN config in bridge, no VLAN interfaces.
RB3011 6.41.4 works fine, but 6.42 && 6.42.1 won’t work.
CRS317 is now 6.42.1.
Note: sometimes I need to reboot CRS317 to make it work.
I have some similar problem. With RTSP active works fine, but without it, no traffic after reboor (6.42.2)
How do you solve the problem? using 6.41.x version?
Please send supout.rif files from both devices to support@mikrotik.com
Also tell us how the two devices are connected, is it a SFP DAC or maybe using a S-RJ01 or S+RJ10 module with a Ethernet cable?
