RB3011 port flopping - bad design
Very good news!!
It’s great that you wrote it publicly on the forum.
Does this mean that a scheduled daily reboot will fix this problem for now?
Nothing scream hack GARBAGE like “requiring daily reboots”.
PLEASE DON’T MAKE ME ADD DAILY REBOOTS TO MY SYSTEMS.
Now It starts flopping on 2 Hex Poe - same switch chipset. Traffic over Hex is about 200 Mbit and there is one 100 Mbit port. I will migrate it to 1Gbit, but it is user router and it spends more money. Will new release fix Hex Poe?
Good news!!!
"Hello,
We have repeated the RB3011 problem, determined that the cause is purely software related and now we are working on fixes which should be done soon.
Thank you for reporting.
Best regards,
Janis B."
Love that MikroTik actual take fault reports seriously!
Do we know how soon is soon?
I guess not…!
Any progress?
Any news on the progress?
My problem with port flopping on the hAP ac might be related to the same problem. Therefore, I am looking foreward to news on the topic…
/axc27
Hello All,
Just checking to see if this is being looked into anymore?
It’s been a while
Still hoping for word of a solution. I’ve found that instead of rebooting the whole switch, I can just bounce the offending interface interface and that clears it up, at least for awhile.
Well that is something.
It has been very quiet on this for a long time, I had just wondered if the team had given up.
Any updates on this topic?
SONY
Soon Only Not Yet
Probably something that isn’t easy to fix so i guess they will eventually say it will be fixed in version 7, that’s another way of saying it won’t be fixed thsi century
Hello, I have purchased a RB3011 and migrated an RB2011, copy all settings via the terminal. However, when I put the RB3011 in the air, the port that reaches my link (ETH1), is in constant UP / DOWN. Due to this situation, I put the rb2011 back and this error does not occur.
Xbox does that exact thing. Have to put a switch in-between or run wireless.
How about they just fix the issue…
Not sure if the Xbox thing IS the same thing as the port flopping… but have seen this since the 2011s came out.
Any progress?
We stopped buying this HW, last good product in Mikrotiks offer is RB1100AHx4, but its twice expensive :frowning:
