RB3011 Speedtest to localhost
I had not seen this test on the forum yet. I hope cores will be used more efficiently in future…
And I hope you will use the router more efficiently in the future :slight_smile: Test to self proves nothing. You must test through the router.
I thought it would give me some indication about performance. Better to setup good test then
Btest uses one cpu core even on CCR1072 (72core), you need to use traffic-generator instead.
