Hey,
So I am trying to configure the switch chip in the RB3011 and am running in to a bit of a problem. Is there something special about VLAN 1?..
Basically I am trying to have
ether01 be the gateway…
ether02-ether05 be switch 1…
ether06-ether10 be switch 2…
I am trying to have vlans 1,100, and 1003 come in as tagged via ports 02 through 09 and SFP. I am then trying to have ether10 be untagged vlan 1.
Right now I have the master-ports configured… I place the master ports into a bridge called “main”. I then placed the vlans on the bridge main… the I made a bridge for each vlan (management, private, public).
My current problem is with VLAN 1. The problem is that it doesn’t seem to work… either as tagged through 02 through 09 or as untagged on ether10.
When I convert it to VLAN 99 it works fine…
Thoughts?
The basic config I’m using is below.
add comment=“Loopback Bridge” mtu=1500 name=bridge-loopback
add comment=“Management Bridge” mtu=1500 name=bridge-management
add comment=“Private Bridge” mtu=1500 name=bridge-private
add comment=“Public Bridge” mtu=1500 name=bridge-public
add comment=“VPN Bridge” mtu=1500 name=bridge-vpn
/interface vlan
add comment=“Management VLAN” interface=bridge-main name=vlan-management vlan-id=1
add comment=“Private VLAN” interface=bridge-main name=vlan-private vlan-id=100
add comment=“Public VLAN” interface=bridge-main name=vlan-public vlan-id=1003
set [ find default-name=ether1 ] name=ether01-gateway
set [ find default-name=ether2 ] name=ether02
set [ find default-name=ether3 ] master-port=ether02 name=ether03
set [ find default-name=ether4 ] master-port=ether02 name=ether04
set [ find default-name=ether5 ] master-port=ether02 name=ether05
set [ find default-name=ether6 ] name=ether06
set [ find default-name=ether7 ] master-port=ether06 name=ether07
set [ find default-name=ether8 ] master-port=ether06 name=ether08
set [ find default-name=ether9 ] master-port=ether06 name=ether09
set [ find default-name=ether10 ] master-port=ether06
set [ find default-name=sfp1 ] master-port=ether02 name=sfp01
set ether02 vlan-mode=secure vlan-header=add-if-missing
set ether03 vlan-mode=secure vlan-header=add-if-missing
set ether04 vlan-mode=secure vlan-header=add-if-missing
set ether05 vlan-mode=secure vlan-header=add-if-missing
set ether06 vlan-mode=secure vlan-header=add-if-missing
set ether07 vlan-mode=secure vlan-header=add-if-missing
set ether08 vlan-mode=secure vlan-header=add-if-missing
set ether09 vlan-mode=secure vlan-header=add-if-missing
set ether10 vlan-mode=secure vlan-header=always-strip default-vlan-id=1
set switch1-cpu vlan-mode=secure vlan-header=add-if-missing
set switch2-cpu vlan-mode=secure vlan-header=add-if-missing
add switch=switch1 ports=switch1_cpu,ether02,ether03,ether04,ether05 vlan-id=1
add switch=switch1 ports=switch1_cpu,ether02,ether03,ether04,ether05 vlan-id=100
add switch=switch1 ports=switch1_cpu,ether02,ether03,ether04,ether05 vlan-id=1003
add switch=switch2 ports=switch2_cpu,ether06,ether07,ether08,ether09,ether10 vlan-id=1
add switch=switch2 ports=switch2_cpu,ether06,ether07,ether08,ether09,ether10 vlan-id=100
add switch=switch2 ports=switch2_cpu,ether06,ether07,ether08,ether09,ether10 vlan-id=1003
add bridge=bridge-public interface=vlan-public
add bridge=bridge-private interface=vlan-private
add bridge=bridge-management interface=vlan-management
add bridge=bridge-main interface=ether02
add bridge=bridge-main interface=ether06
add bridge=bridge-main interface=sfp01
