RB3011: Switch-flag "Switch all ports" forget status
Hi folks,
I tried to set the switch-flag via script, but it isn’t set, the script is just ignored.
/interface ethernet switch set 0 name=switch1 switch-all-ports=yes
And: If the flag has been set manually: After logout and login to winbox the status of the flag is gone or back to inaktiv.
Do I use it in wrong matter or is it a bug?
That option doesn’t apply to the 3011. Only to the RB850 and some similar. Use master ports (pre-6.41) or a bridge (6.41+) to set up switch groups.
Ah, okay. As I run 6.41 I just have to trust the HW-offload via bridges. Thank you → SOLVED
In fact it is noticed here: https://wiki.mikrotik.com/wiki/Manual:Switch_Chip_Features… I should read the f…unny manual…
So, maybe in a new version the flag should be marked grey/unusable for RB3011 and other devices anyway…
