Looks like I have the same or related issue with RB3011: some packets are seemingly coming untagged from an access port, this results in input from the master bridge instead of configured VLAN.
I have switch and interface setup as described in https://wiki.mikrotik.com/wiki/Manual:Basic_VLAN_switching#Other_devices_with_built-in_switch_chip.
ISP is connected to ether2, all internal clients on access switch connected to ether10.
The issue is not observed if ISP is connected thru an access switch on trunk port (ether1).
The config (related part) is:
add name=bridge-master protocol-mode=none
add bridge=bridge-master interface=ether1
add bridge=bridge-master interface=ether10
add bridge=bridge-master interface=ether2
add bridge=bridge-master interface=ether3
add bridge=bridge-master interface=ether4
add bridge=bridge-master interface=ether5
add bridge=bridge-master interface=ether6
add bridge=bridge-master interface=ether7
add bridge=bridge-master interface=ether8
add bridge=bridge-master interface=ether9
/interface vlan
add interface=bridge-master loop-protect=off name=vlan-isp vlan-id=10
add interface=bridge-master name=vlan-private vlan-id=20
set 0 vlan-header=add-if-missing vlan-mode=secure
set 1 default-vlan-id=10 vlan-header=always-strip vlan-mode=secure
set 2 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 3 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 4 vlan-header=add-if-missing vlan-mode=secure
set 5 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 6 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 7 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 8 default-vlan-id=20 vlan-header=always-strip vlan-mode=secure
set 9 vlan-header=add-if-missing vlan-mode=secure
set 10 vlan-header=add-if-missing vlan-mode=secure
set 11 vlan-header=add-if-missing vlan-mode=secure
add independent-learning=yes ports=switch1-cpu,ether1,ether2 switch=switch1 \
vlan-id=10
add independent-learning=yes ports=\
switch1-cpu,ether1,ether3,ether4,ether5 switch=switch1 vlan-id=20
switch2-cpu,ether6,ether7,ether8,ether9,ether10 switch=switch2 vlan-id=20
add address=<internal IP>/24 interface=vlan-private network=<internal net>
add address=<external IP>/24 interface=vlan-isp network=<ISP net>
add action=drop chain=input comment="master bridge leakage" in-interface=\
bridge-master log=yes
HW offload is on all ports:
# INTERFACE BRIDGE HW PVID PR PATH-COST INTERNA... HORIZON
0 I H ether1 bridge-master yes 1 0x 10 10 none
1 H ether10 bridge-master yes 1 0x 10 10 none
2 H ether2 bridge-master yes 1 0x 10 10 none
3 I H ether3 bridge-master yes 1 0x 10 10 none
4 I H ether4 bridge-master yes 1 0x 10 10 none
5 I H ether5 bridge-master yes 1 0x 10 10 none
6 I H ether6 bridge-master yes 1 0x 10 10 none
7 I H ether7 bridge-master yes 1 0x 10 10 none
8 I H ether8 bridge-master yes 1 0x 10 10 none
9 I H ether9 bridge-master yes 1 0x 10 10 none
All packets from ISP should go to vlan-isp (and there’s no IP addresses on master bridge), still some packets are seeping through:
08:31:22 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (SYN), 79.167.15.240:13670-><my ext IP>:88, len 40
09:07:12 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (SYN), 221.213.237.97:25555-><my ext IP>:23, len 40
09:15:16 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (RST), 13.33.241.79:443-><my ext IP>:52236, len 40
09:28:24 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (ACK), 66.211.182.222:443-><my ext IP>:4782, len 52
10:03:16 firewall,info input: in:bridge-master out:(unknown 0), src-mac <ISP gw MAC>, proto TCP (RST), 173.194.73.99:443-><my ext IP>:53142, len 40
