RB3011 UNIFY VLAN
im trying to configure RB3011 with 5 UnifyAP.
So i have eth1 as WAN, AP connected to 2,3,4 5 cable bridge to 6 and 7 and 8.
On Unify AP i have 2 SSIDs one Main and second for Guests, Main have VLAN10, Guest VLAN20.
The goal is to have VLAN10 with dhcp 192.168.176.20-192.168.177.254 without limits, and VLAN20 with dhcp 10.0.0.2-10.0.0.254 and limit 15M up/down for whole VLAN20.
And i fail :slight_smile:
VLAN10 dhcp works, VLAN20 also but without internet acess, and limits dont work in any situation.
/interface vlan
add interface=ether2 name=eth2-vlan10 vlan-id=10
add interface=ether2 name=eth2-vlan20 vlan-id=20
add interface=ether3 name=eth3-vlan10 vlan-id=10
add interface=ether3 name=eth3-vlan20 vlan-id=20
add interface=ether4 name=eth4-vlan10 vlan-id=10
add interface=ether4 name=eth4-vlan20 vlan-id=20
add interface=ether5 name=eth5-vlan10 vlan-id=10
add interface=ether5 name=eth5-vlan20 vlan-id=20
add interface=ether6 name=eth6-vlan10 vlan-id=10
add interface=ether6 name=eth6-vlan20 vlan-id=20
add interface=ether7 name=eth7-vlan10 vlan-id=10
add interface=ether7 name=eth7-vlan20 vlan-id=20
add interface=ether8 name=eth8-vlan10 vlan-id=10
add interface=ether8 name=eth8-vlan20 vlan-id=20
add name=bridge-vlan10
add name=bridge-vlan20
add bridge=bridge-vlan10 interface=eth2-vlan10
add bridge=bridge-vlan10 interface=eth3-vlan10
add bridge=bridge-vlan10 interface=eth4-vlan10
add bridge=bridge-vlan10 interface=eth5-vlan10
add bridge=bridge-vlan10 interface=eth6-vlan10
add bridge=bridge-vlan10 interface=eth7-vlan10
add bridge=bridge-vlan10 interface=eth8-vlan10
add bridge=bridge-vlan20 interface=eth2-vlan20
add bridge=bridge-vlan20 interface=eth3-vlan20
add bridge=bridge-vlan20 interface=eth4-vlan20
add bridge=bridge-vlan20 interface=eth5-vlan20
add bridge=bridge-vlan20 interface=eth6-vlan20
add bridge=bridge-vlan20 interface=eth7-vlan20
add bridge=bridge-vlan20 interface=eth8-vlan20
/queue simple
add name=vlan20_limit target=10.0.0.0/24 max-limit=15M/15M
!!! disable fasttrack connections rule in firewall filter section if you have!!!
