RB3011
Hello
I have install a RB3011 with OS 6.34.3.
My configuration is the following
ether1 management
ether2 LAN1
ether3 LAN2
ether4 LAN3
ether5 LAN5
ether6 WAN1
ether7 WAN2
ether8 WAN3
ether9 WAN4
My external IP´s look like this WAN1 111.111.111.1, WAN2 111.111.111.2,WAN3 111.111.111.3,WAN4 111.111.111.4
Gateway is 111.111.111.6
Now i have configured that LAN1 goes out to WAN1, LAN2 to WAN2, LAN3 to WAN3, LAN4 to WAN4.
My configuration works, but it´s not possible to ping from any of the LAN to WAN. I only can ping directly from the RB.
But my problem is the ping responsetime that is between 500-600ms. When i perform a speedtest is the down ~ 9000 an the up ~ 200. The down rate is ok, but the up is tho low. my ISP is 10/1 MBit.
Have anyone an idea who to fix this
thanks bernhard
is all your wan IP’s in the same subnet?
If so that may be the issue because MT creates a automatic route when you add a ip.
IF you have 5 IP’s on different interfaces on the same subnet then there is a problem.
Also is the same 4 wan ports connecting to the same physical gateway device?
Hello
my wan address are all in the same subnet.
can you give me an info who the rules must be
thanks
i have change that all the wan addresses to one interface but it also not working.
