I have been using an RB3011UiAS since last year with a Ubiquiti UniFi AP-AC-LR connected via ether10, and has been working flawlessly until today.
Today I upgraded the RB3011UiAS firmware to 6.42.2 (Not sure which firmware version I had before, but it has been a year since its firmware was updated), and PoE seems to have has stopped working. Did some searching and used ‘interface ethernet poe set ether10 poe-out=forced-on’ via terminal, and confirmed via print that it is actually forced-on, however my AP still did not want to get an IP via DHCP. I checked the AP manual and it states 24V.
Tested the AP by using the PoE provided by UBQT, connected to ether4 and it worked, connected the AP directly to ether10 again, and the issue is there again.
Has something changed with regards to ether10 and PoE, or do I have a problem with my router?
