RB3011UiAS POE Port
Greetings
I have a RB3011UiAS and i want to use the last port to provide power to a Ubiquiti Cloud Key
how do i enable this port to power on the device?
Should be auto-on, so just plug it in. But you can see the settings here:
/interface ether poe
You will need to use an 802.11af power injector. The RB3011 doesn’t support 802.11af.
thanks for all responses
So this model does not have the option to power up a POE…
Which one of the other routers does have this option?
The router can power other MikroTik devices. At this time MikroTik does not have any 801.11af support.
