Hi all.
I have two RB3011 connected with Ethernet and SPF (not bonded) on firmware version 7.2.1. All traffic is sent via Ethernet only and the one router gives PoE to the other from port 10 to port 1. After an upgrade to firmware 7.3 the router goes into a boot loop when it seems to start the SPF interface. When I disconnect the physical fiber from the SPF the router boots. When I connect the fiber the router reboots. I’ve downgraded to 7.2.1 and it works fine.
It seems there’s a bug in the new firmware then?
Details on the SPF:
Vendor: UBNT
Part Number: UF-MM-1G
Does anybody else have this issue?
