RB3011UiAS-RM, RouterOS 6.33.5
If I shutdown router from Winbox, it reboots after 30 seconds.
Has anyone the same issue?
yes, i have the same problem here.
As it was explained here at forum, it is not an issue. We should not to shut down router in a common case.
It is safe enough to switch off mikrotik without shutdown.
thank you for the info
