I have a RB333 (OS 3.10) using eth1 with internal IP and eth2 for WAN. I have a web server on the inside and I want the pubic to be able to access the port 80 as well as the port 22 (ssh). I read the the wiki and I can not get it to work. Seems simple enough but when I config the NAT as dst it does not work. Got some information that might help? Thanks in advance.
Post your configuration.
Not much of a configuration… A t1 going into a router, then from the router to the mikrotik 333 in eth2 then the LAN in eth1. No firewall rules, and masq in the NAT. That’s about it. If I change the MT to another usable IP I can get to it. It just does not work correctly for the NAT.
You have to configure dst-nat & src-nat rule with netmap…
