I replaced my old rb333 with a new hap-ac by backing up the config in the rb333 and restoring it in the hap-ac and masquarade works but src-nat and dst-nat do not work so none of my servers can be accessed remotly and i can’t srcnat traffic through specific public IP’s
How have you restored configuration ?
Have you removed default configuration ?
What is ROS version in the hAP ?
Are you sure that full original configuration is restored ?
Have you backed configuration from the same ROS version as installed in the hAP ?
Have you compared visually running configuration for both routers … same count of firewall rules, same order, etc. … ?
