RB333, with r52h and alfa 1 watt failure
hello
i have 333 boad with r52h on the 5.8 band to connect main station, i install another mini-pci card from alfanetworks delivers 1 watt on 2.4 Ghz to serve about 20 users. before that i was using rb532A with the alfa,but the 532 stop working so i moved the mini-pci card to the 333. the covarege range now is lower. many users cannot connect to the signal, i checked averything in setting there is nothing wrong, can the RB333 work successfully with these 2 cards ? is there any suggestions ?
Post your configuration.
0 R name=“*" mtu=1500 mac-address=00:0C:42:18:5C:15 arp=enabled
interface-type=Atheros AR5413 mode=station-wds ssid="
frequency=5210 band=5ghz-turbo scan-list=default antenna-mode=ant-a
wds-mode=dynamic wds-default-bridge=bridge1 wds-ignore-ssid=no
default-authentication=yes default-forwarding=yes default-ap-tx-limit=0
default-client-tx-limit=0 hide-ssid=no security-profile=5.8
compression=no
1 R name=“" mtu=1500 mac-address=00:C0:CA:1A:26:78 arp=enabled
interface-type=Atheros AR5413 mode=ap-bridge
ssid="
” frequency=2442 band=2.4ghz-b/g
scan-list=default antenna-mode=ant-a wds-mode=disabled
wds-default-bridge=none wds-ignore-ssid=no default-authentication=yes
default-forwarding=yes default-ap-tx-limit=0 default-client-tx-limit=0
hide-ssid=no security-profile=default compression=no
need to do a print detail
