RB333
Can someone from MikroTik tell me what consequences wuld be it the markeed element on the picture woul broke
http://shrani.si/?1P/oz/2jm5C1i2/rb333s1.jpg
can you tell me the number? from the picture it seems you are pointing at the hole :slight_smile:
may be a-l-i-e-n talk about element witch is under hole?zoom is cool thing :slight_smile:
zoom and you will see it… it is a very small element looks like a resistor or a capacitor
I don’t see any options to zoom there.
save it to your computer then zoom in
well duh, it’s still a small image, zooming won’t help make it better quality. just email support with the part number.
do you have any larger picture of the board… ?
Is it the two small ones left to the text “C810” ?
yes that is the one, finaly I got a bigger picture of rb333
http://static.album.email.si/2/0/435020/OTnO2rrrcBcYayUjmBk06.jpg
Res 0402 6,8k Actually you can use RB without it and next time work with screwdriver more carefully :slight_smile:)
yes, this part (R829 6.8KOhm) is for voltage monitoring, and RB will work without it too.
thank you so mouch! I’m realy happy that’s nothing serious…
And I was wondering why it shows a big drop in voltage… that’s why… :slight_smile:
