RB4011 after upgrade from 7.1 to v7.3.1 cannot ping and into winbox.
Hello everyone.
I have a RB4011iGS+5HacQ2HnD-IN. I did upgrade in the winbox from 7.1 to v7.3.1, after reboot it cannot ping and cannot into webfig or winbox. But Other parts work fine, Why is this?
Do you have multi WAN or VPN and use mangle roules to direct traffic certain way? If so, you’re hit by unexpected change in priority of marked packets. See e.g. this thread: http://forum.mikrotik.com/t/routing-priority-issue/158587/1
Hopefully you didn’t disable WinBox connection to MAC address, so use that to get back, and they you’ll need to change mangle rules to exclude local destinations (dst-address-type=!local).
yes, I have two WAN and use mangle roules, but i disable WinBox connection to MAC address, can i connect it with console interface?
If you can’t connect through IP or MAC you can always use a console cable yes…
Thank you, I used console cable to connect to the router, after fixing mangle rule router the router works find.
