Hello all
Just had my 4011 delivered and I’m about to export my config from 2011 to it. Not sure if this is a new feature but where is the beep on startup/reboot or do I have a faulty board.
Here, https://i.mt.lv/cdn/rb_files/1561709233RB4011-iGS-5HacQ2HnD-IN.pdf it says it will beep after short boot up.
It’s not a big deal if this is the way they’re going with it, just found it odd that after using multiple 2011’s 1200’s 1100x4’s that they have stopped it.
