RB4011 bricked in boot loop, please help
I have RB4011iGS+5HacQ2HnD that was running RouterOS 6.48 recently.
I have logged in, checked for update and saw that there’s new version 6.48.3 available. I used the packages → upgrade option to download the new version and reboot.
The reboot went well but the version stayed the same as before at 6.48. I repeated the procedure several times to no avail.
I tried also downloading the .npk, placing it to files and rebooting. The .npk file disappears but the version does not move.
I also tried to re-flash the already-running 6.48 and then tried to upgrade but again - no luck.
I got upset because this is a second router that I own that has the same issue. On my second one I’m stuck at 6.47.
So I decided to do Netinstall. I went to the product page at https://mikrotik.com/product/rb4011igs_5hacq2hnd_in went to “Support and downloads” clicked “RouterOS current release” and downloaded routeros-arm-6.48.3.npk
Then I proceeded with netinstall. Everything went well but after the reboot the router is bricked and won’t boot even if I reflash it back with 6.48 (that was previously working).
I get as boot loop with the following messages:
AL31400X-140
RouterBOOT booter 6.48
RB4011iGS+5HacQ2HnD
CPU frequency: 1400 MHz
  Memory size: 1024 MiB
    NAND size: 512 MiB
Press any key within 2 seconds to enter setup..
loading kernel... OK
setting up elf image... OK
jumping to kernel code
opendir: No such file or directory
ERROR: no system package found!
Kernel panic - not syncing: Attempted to kill init!
{bf84df0c} panic+0x84/0x1c0
{bf84df44} do_exit+0x80/0x688
{bf84df84} do_group_exit+0x4c/0xc0
{bf84df9c} __wake_up_parent+0x0/0x18
CPU1: stopping
{bf879f5c} handle_IPI+0xf4/0x1e0
{bf879f7c} gic_handle_irq+0x94/0xa4
{bf879f94} __irq_svc+0x40/0x60
Exception stack(0xbf879f98 to 0xbf879fe0)
9f80:                                                       80d2c890 00000000
9fa0: bf879fe0 00000000 bf878000 804e9a48 804a1a78 804e9cc8 0000406a 412fc0f4
9fc0: 00000000 00000000 00000000 bf879fe0 8000e860 8000e864 60000013 ffffffff
{bf879fdc} default_idle+0x24/0x28
{bf879fe4} cpu_idle+0x50/0x8c
{bf879ff4} 0x486174
CPU3: stopping
{bf891f5c} handle_IPI+0xf4/0x1e0
{bf891f7c} gic_handle_irq+0x94/0xa4
{bf891f94} __irq_svc+0x40/0x60
Exception stack(0xbf891f98 to 0xbf891fe0)
1f80:                                                       80d46890 00000000
1fa0: bf891fe0 00000000 bf890000 804e9a48 804a1a78 804e9cc8 0000406a 412fc0f4
<4>1fc0: 00000000 00000000 00000003 bf891fe0 8000e860 8000e864 60000113 ffffffff
{bf891fdc} default_idle+0x24/0x28
{bf891fe4} cpu_idle+0x50/0x8c
{bf891ff4} 0x486174
CPU2: stopping
{bf883f5c} handle_IPI+0xf4/0x1e0
{bf883f7c} gic_handle_irq+0x94/0xa4
{bf883f94} __irq_svc+0x40/0x60
Exception stack(0xbf883f98 to 0xbf883fe0)
3f80:                                                       80d39890 00000000
3fa0: bf883fe0 00000000 bf882000 804e9a48 804a1a78 804e9cc8 0000406a 412fc0f4
3fc0: 00000000 00000000 00000000 bf883fe0 8000e860 8000e864 60000013 ffffffff
{bf883fdc} default_idle+0x24/0x28
{bf883fe4} cpu_idle+0x50/0x8c
{bf883ff4} 0x486174
Rebooting in 1 seconds..:00000050
