RB4011 cannot Netinstall
Have a strange problem with multiple RB4011, cannot Netinstall
In Netinstall I see the RB, but installing process stuck on “sending offer”
On all another MT devices, Netinstalling goes fine, without any problem.
My system is windows 10.
I try to disabled the FW, used usb ethernet, disabled all another interfaces… nothing helps.
RB4011 cannot netinstall, all another goes fine.
Is this some specific problem with RB4011?
Have you tried connecting the RB4011 and your PC with a switch in between and then performing Netinstall?
Another user had problems with netinstall on RB4011 and using latest beta netinstall helped.
http://forum.mikrotik.com/t/unable-to-upgrade-rb4011/127230/1
Hello. RB4011iGS+5HacQ2HnD-IN coldn’t update from netinstall version 7.1rc1 (32bit and 64bit) to firmware 7.1rc1 Netinstall show status run. When put install not installing. Try install with netinstall version 6.47.10 - same with these version. I can installen only with 6.48.4.
I check on fw version on all version 6.47.10, 6.48.4, 7.1beta7
Disable any firewall or antivirus program running on your computer..
Disable any other network adapter except the ethernet one used for Netinstall..
Try different versions of Netinstall…
Use a switch between RB4011 and your computer, as already suggested…
