If I buy these two devices will it be possible link them with the SFP+ ports using S+AO0005 10Gbps Active Optics direct attach cable? Will it be also possible to USE the POE in Port for backup power and a backup link to the switch?
Thanks for your help, I am looking at buying this set up tomorrow unless anyone else can recommend better? Currently using RB3011 as CapsMan etc. but expanding and need a switch now with POE ports.
