RB4011 Odd Behavior
RB4011iGS+
6.44.5 (long-term)
I logged in via Winbox and could see the CPU was 25% for no apparent reason, however interface & firewall pages did not load any data. Performed a reboot, and it took 7 minutes for it to fully boot. No Interface link lights until 7 minutes in and it started working, and I could login. Winbox appeared normal with the exception that it erased all but the built-in interface lists and as such it broke some of the firewall rules that referenced those interface lists. Anyone else run into anything similar with their RB4011?
Yes see here: http://forum.mikrotik.com/t/rb4011-high-uneven-cpu-load-and-a-crash/132268/1
I can also see from a number of 4011’s I’ve got out in the wild that cpu0 get hammered all the time and the other 3 do very very little :confused:
which is your current firmware in system -->routerboard ??
/system routerboard print
(firmware not routeros)
For me 6.45.3 same as ROS.
Try to netinstall the device to the latest version and see how it goes…
