RB4011 Reboots when try to check for updates
Please Help me, with these issue.
  • Reboots when I open Check for Update Window
  • Reboots when I change update channel from Long Term to Other
  • Reboots while it checks for update
Its a brand new RB4011 Revision :r2,
Started happening after updating to 6.47.1 ROS and Firmware.
I used Winbox 3.22 -64 bit & 3.24 - 64Bit.
Same issue was faced
it seems the issue is with 5Ghz Wifi channel. i have manually set to 5180. now there is no issue.
my RB4011 is US version.
Can it be the Issue ??
Nop it doesn’t work
Very strange. Contact to Mikrotik support.
Regards.
the issue has come back.
Change of Channel is not working,
Mikrotik support not working
Give them a few business days to respond. Update manually if you need to switch between branches.
Please be patient. They only works on week days.
Regards.
No news of support, there service desk page also not working for me.
Really upset. cannot use 5Ghz or Check for update.
If anyone has a idea, pls Help
Can you please share your config?
/export hide-sensitive file=whateveryoulike
Have you already reset the device and reconfigured it?
(By importing the export you can return to the current configuration any time)
whateveryoulike.rsc (52.4 KB)
