RB4011 ... same mac address sfp-sfplus1 and wlan1 ... solution for 6.44.6 ?
Hello
I still have the issue of same mac address sfp-sfplus1 and wlan1 on my RB4011iGS+5HacQ2HnD-IN.
Is there a solution for 6.44.6 ?
On 6.46.2 i could do a “/interface wireless reset-configuration wlan1” to solve this problem … not ?
Richard
I seem to remember that for years it has been possible to reset a wireless interface back to its original MAC address, but not an ethernet interface… or perhaps vice versa.
However, you can fix the problem the same way it was probably caused – instead of looking for a reset, determine what the proper hardware address of the interface should be, and just use the set command to set it to its original address. Most often these are available on the product label.
