I have my RGB4011 setup with all its VLANs on sfp-sfpplus1, it’s also the uplink to my switch. Internet comes in on ether1. For some reason routing between VLANs is super slow. Any ideas on what could cause this, or is it due to the fact that I do not have a bridge setup?
Config here.
# jan/18/2002 23:56:34 by RouterOS 7.1rc4
# software id =
# model = RB4011iGS+
# serial number =
set [ find default-name=ether2 ] disabled=yes
set [ find default-name=ether3 ] disabled=yes
set [ find default-name=ether4 ] disabled=yes
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes poe-out=off
/interface vlan
add interface=sfp-sfpplus1 name="Guest Wifi" vlan-id=200
add interface=sfp-sfpplus1 name=IoT vlan-id=10
add interface=sfp-sfpplus1 name=VMs vlan-id=20
add interface=sfp-sfpplus1 name=Wifi vlan-id=7
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1 name=pppoe-out user=\
no@no.no
add name=WAN
add name=LAN
/interface lte apn
set [ find default=yes ] ip-type=ipv4
/ip dhcp-server option
add code=42 name=NTPVMs value="'172.16.20.1'"
add code=42 name=NTPLAN value="'172.16.6.1'"
add code=42 name=NTPIoT value="'172.16.10.1'"
add code=42 name=NTPWifi value="'172.16.7.1'"
add code=42 name="NTPGuest Wifi" value="'172.16.200.1'"
/ip dhcp-server option sets
add name=Wifi options=NTPWifi
add name=LAN options=NTPLAN
add name=VMs options=NTPVMs
add name="Guest Wifi" options="NTPGuest Wifi"
add name=IoT options=NTPIoT
/ip ipsec profile
set [ find default=yes ] dh-group=modp2048 enc-algorithm=aes-128 \
hash-algorithm=sha256
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=\
aes-256-gcm,aes-192-ctr,aes-192-gcm,aes-128-gcm lifetime=0s pfs-group=\
modp2048
add name=IoT_pool ranges=172.16.10.100-172.16.10.254
add name=LAN_pool ranges=172.16.6.100-172.16.6.254
add name="Guest Wifi_pool" ranges=172.16.200.2-172.16.200.254
add name=VMs_pool ranges=172.16.20.100-172.16.20.254
add name=Wifi_pool ranges=172.16.7.100-172.16.7.254
add address-pool=IoT_pool dhcp-option-set=IoT interface=IoT lease-time=1w \
name=IoT
add address-pool=LAN_pool dhcp-option-set=LAN interface=sfp-sfpplus1 \
lease-time=1w name=LAN
add address-pool="Guest Wifi_pool" dhcp-option-set="Guest Wifi" interface=\
"Guest Wifi" lease-time=1w name="Guest Wifi"
add address-pool=VMs_pool dhcp-option-set=VMs interface=VMs lease-time=1w \
name=VMs
add address-pool=Wifi_pool dhcp-option-set=Wifi interface=Wifi lease-time=1w \
name=Wifi
/queue simple
add burst-limit=2M/2M burst-threshold=2M/2M burst-time=10s/10s comment=\
"Guest Wifi" limit-at=1M/1M max-limit=1M/1M name="Guest Wifi" priority=\
6/6 queue=default/default target="Guest Wifi"
/routing bgp template
set default as=65530 disabled=no name=default output.network=bgp-networks
/routing table
add fib name=""
/system logging action
set 3 remote=172.16.6.2
add bsd-syslog=yes name=unRAID remote=172.16.6.2 src-address=172.16.6.1 \
target=remote
/zerotier
set zt1 comment="ZeroTier Central controller - https://my.zerotier.com/" \
identity="dd" name=zt1 \
port=9993
/zerotier interface
add instance=zt1 mac-address=dd name=zerotier1 network=\
dd
set discover-interface-list=none
add interface=ether1 list=WAN
add interface=sfp-sfpplus1 list=LAN
add interface="Guest Wifi" list=LAN
add interface=IoT list=LAN
add interface=VMs list=LAN
add interface=Wifi list=LAN
add interface=pppoe-out list=WAN
add address=172.16.6.1/24 interface=sfp-sfpplus1 network=172.16.6.0
add address=172.16.7.1/24 interface=Wifi network=172.16.7.0
add address=172.16.10.1/24 interface=IoT network=172.16.10.0
add address=172.16.20.1/24 interface=VMs network=172.16.20.0
add address=172.16.200.1/24 interface="Guest Wifi" network=172.16.200.0
add address=192.168.254.253/24 interface=ether1 network=192.168.254.0
/ip cloud
set ddns-enabled=yes
/ip dhcp-server lease
add address=172.16.10.2 client-id=HeidiNightstand mac-address=\
60:38:E0:F1:C8:71
add address=172.16.10.5 client-id=HueBridge mac-address=dd
add address=172.16.7.5 client-id=erx mac-address=04:18:D6:06:18:6F
add address=172.16.7.15 mac-address=70:2C:09:69:FF:88
add address=172.16.10.4 client-id=1:b0:be:76:46:b9:92 mac-address=\
B0:BE:76:46:B9:92 server=IoT
add address=172.16.7.4 client-id=1:44:90:bb:5:c0:cd mac-address=\
44:90:BB:05:C0:CD server=Wifi
add address=172.16.10.3 client-id=1:2c:aa:8e:d6:93:4c mac-address=\
2C:AA:8E:D6:93:4C server=IoT
add address=172.16.7.3 client-id=1:dc:52:85:d4:15:9f mac-address=\
DC:52:85:D4:15:9F server=Wifi
add address=172.16.20.3 client-id=1:52:54:0:c8:d0:49 mac-address=\
52:54:00:C8:D0:49 server=VMs
add address=172.16.20.4 client-id=1:52:54:0:be:8c:1c mac-address=\
52:54:00:BE:8C:1C server=VMs
add address=172.16.6.0/24 dns-server=172.16.6.1 domain=mccloud.lan gateway=\
172.16.6.1 netmask=24
add address=172.16.7.0/24 dns-server=172.16.7.1 domain=mccloud.lan gateway=\
172.16.7.1
add address=172.16.10.0/24 dns-server=172.16.10.1 domain=mccloud.lan gateway=\
172.16.10.1
add address=172.16.20.0/24 dns-server=172.16.20.1 domain=mccloud.lan gateway=\
172.16.20.1
add address=172.16.200.0/24 dns-server=172.16.200.1 domain=mccloud.lan \
gateway=172.16.200.1
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=172.16.6.2 name=transmission.no.no
add address=172.16.6.2 name=unimus.no.no
add address=172.16.6.2 name=airsonic.no.no
add address=172.16.6.2 name=home.no.no
add address=172.16.6.2 name=jackett.no.no
add address=172.16.20.3 name=jenkins.no.no
add address=172.16.6.2 name=lidarr.no.no
add address=172.16.6.2 name=nzbget.no.no
add address=172.16.6.2 name=omada.no.no
add address=172.16.6.2 name=ombi.no.no
add address=172.16.6.2 name=paperless.no.no
add address=172.16.6.2 name=piwigo.no.no
add address=172.16.6.2 name=plex.no.no
add address=172.16.6.2 name=radarr.no.no
add address=172.16.6.2 name=sonarr.no.no
add address=172.16.6.2 name=speedtest.no.no
add address=172.16.6.2 name=subversion.no.no
add address=172.16.6.2 name=syncthing.no.no
add address=172.16.6.2 name=tautulli.no.no
add address=172.16.6.2 name=tdarr.no.no
add address=172.16.20.3 name=jumpbox
add address=172.16.6.2 name=bb-8
add address=172.16.20.3 name=jumpbox.mccloud.lan
add address=172.16.6.2 name=bb-8.mccloud.lan
add action=accept chain=forward connection-state=\
established,related,untracked
add action=accept chain=input connection-state=established,related,untracked
add action=accept chain=output connection-state=established,related,untracked
add action=drop chain=input connection-state=invalid
add action=accept chain=input in-interface=pppoe-out protocol=icmp
add action=drop chain=input in-interface=pppoe-out
add action=drop chain=forward in-interface="Guest Wifi" out-interface=IoT
add action=drop chain=forward in-interface="Guest Wifi" out-interface=VMs
add action=drop chain=forward in-interface="Guest Wifi" out-interface=Wifi
add action=drop chain=forward in-interface="Guest Wifi" out-interface=\
sfp-sfpplus1
add action=drop chain=forward in-interface=IoT out-interface="Guest Wifi"
add action=drop chain=forward in-interface=VMs out-interface="Guest Wifi"
add action=drop chain=forward in-interface=Wifi out-interface="Guest Wifi"
add action=drop chain=forward in-interface=sfp-sfpplus1 out-interface=\
"Guest Wifi"
add action=fasttrack-connection chain=forward connection-mark=!ipsec \
add action=fasttrack-connection chain=input connection-mark=!ipsec \
add action=fasttrack-connection chain=output connection-mark=!ipsec \
connection-mark=!ipsec connection-state=established,related hw-offload=\
yes
add action=accept chain=forward comment="all from WAN DSTNATed" \
connection-nat-state=dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat comment=SSH in-interface=pppoe-out port=no \
protocol=tcp to-addresses=172.16.6.2 to-ports=no
add action=dst-nat chain=dstnat comment=HTTP in-interface=pppoe-out port=no \
add action=dst-nat chain=dstnat comment=HTTPS in-interface=pppoe-out port=no \
add action=dst-nat chain=dstnat comment=RDP in-interface=pppoe-out port=no \
protocol=tcp to-addresses=172.16.20.3 to-ports=no
protocol=udp to-addresses=172.16.20.3 to-ports=no
add action=dst-nat chain=dstnat comment=Plex in-interface=pppoe-out port=\
no protocol=tcp to-addresses=172.16.6.2 to-ports=no
add action=dst-nat chain=dstnat comment=Syncthing in-interface=pppoe-out \
port=no protocol=tcp to-addresses=172.16.6.2 to-ports=no
add action=dst-nat chain=dstnat comment=Syncthing port=no protocol=udp \
add action=dst-nat chain=dstnat comment=Transmission dst-address=172.16.6.2 \
in-interface=pppoe-out port=no protocol=tcp to-addresses=172.16.6.2 \
to-ports=no
in-interface=pppoe-out port=no protocol=udp to-addresses=172.16.6.2 \
to-ports=no
add action=dst-nat chain=dstnat comment="Resilio Sync" in-interface=pppoe-out \
port=no protocol=udp to-addresses=172.16.6.2 to-ports=no
add action=masquerade chain=srcnat comment="nat to modem" dst-address=\
192.168.254.254 out-interface=ether1
add action=masquerade chain=srcnat comment=Masquerade out-interface-list=WAN
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set www-ssl certificate=router disabled=no tls-version=only-1.2
set api disabled=yes
set api-ssl certificate=router tls-version=only-1.2
/ip ssh
set strong-crypto=yes
/ipv6 nd
set [ find default=yes ] advertise-dns=no
/snmp
set contact=smccloud@no.no enabled=yes location="Mechanical Room"
/system clock
set time-zone-name=America/Chicah
/system identity
set name=RB4011iGS+RM
/system logging
add action=remote topics=critical
add action=remote topics=error
add action=remote topics=info
add action=remote topics=warning
/system ntp client
set enabled=yes mode=multicast
/system ntp server
set enabled=yes manycast=yes multicast=yes
/system ntp client servers
add address=128.101.101.101
add address=134.84.84.84
/system package update
set channel=development
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool bandwidth-server
set authenticate=no enabled=no
/tool mac-server
/tool mac-server mac-winbox
/tool mac-server ping
set enabled=no
