RB4011 to control cAPax with CAPSMAN?
I have a RB4011iGS+ and just got a cAPax. I stayed with Mikrotik despite the huge learning curve, because of CAPSMAN and the hope I can control the Wifi router with is. The RB doesn’t have Wifi, the cAPax is wired to it.
Now I read a bunch of threads saying CAPSMAN doesn’t work with wifiwave2, wifiwave2 doesn’t work on RB4011 etc…
I don’t see a way to install Wifiwave2 on my RB. I don’t even see any way to download packages with the RB after upgrading to v7.11.2, so the rumors may be true…
Nevertheless I’m staying hopeful there is a way, and I was wondering if controlling WifiWave2 devices like the cAPax is possible with the wireless package on the RB4011 v7.11.2?
So far my attempts at starting a CAPSMAN server on the RB and CAP on wifiwave2 on the cAPax have only resulted in no communication with little understanding of what may be wrong. Any hint at how to do this please?
If you only have 1 cap AX, why use capsman ? Configure everything on cap AX and be done with it.
If you want to install wifiwave2 package on RB4011, it can be done but then you need to download extra packages.
In there is wifiwave2 package.
Drop on Files section of your RB4011 and reboot. Wifiwave2 will be present.
Use vlans to organize each subnet required ( dont use bridge aka no address or dhcp) and use this excellent guide…http://forum.mikrotik.com/t/using-routeros-to-vlan-your-network/126489/1
For the capax, its an AP/switch and real easy to configure based on the above advice and this guidance … https://forum.mikrotik.com/viewtopic.php?t=182276
