rb4011 v7.9.2 Need downgrade but I cant
I buy rb4011 with v7.9.2 firmware.
I need downgrade to any 6.x.x version.
I try many times with a downgrade procedure but always stay in a same 7.9.2
Can help me please ?
Many thanks
You can not downgrade below factory firmware version.
What does your device show using System / Routerboard ?
The 4011 is new and comes with
Factory Firmware v7.9.2
Current Firmware v7.9.2
Upgrade Firmware v7.9.2
My problem is when I try to upload an backup rsc script from other 4011 with v6.48
Why Mikrotik make this ???
:blush:
Adapt script to ROS7.
Not much else you can do about it…
Before importing the backup script, have you made sure that the device is reset with “No Default Configuration” is checked and wifi devices are enabled?
You can also do the config with the script file line by line through terminal. At least you get feedback on where the script file is failing.
