Hi all,
I have a RB4011 with wireless that has been working fine, but now I had to move it to another place and I don’t cover my entire house anymore. I’m looking into buying some WIFI6 gear for future proofing my network, and I set my eyes on the hap AX3. How would the RB4011 doing PPPoE and the hap AX3 work together on the wireless front? Can I keep a single SSID for both routers and 2.4GHz adn 5GHz, the way I’m doing now with the RB4011? is the transfer between the two APs transparent? Mind, I would also think the AX3 as a “backup” for the RB4011 in case I need to do PPPoE with my ISP, VLAN, etc.
If not, should I pick up some OMAHA EAP whatever?
