RB4011iGS+5HacQ2HnD-IN: 5 GHz "initializing"
  1. routeros-7.0beta1-arm.npk
  2. RB4011iGS+5HacQ2HnD-IN
  3. Just enable 5 GHz, set frequency to 5180 ceee, no secondary frequency, scan list to 5180
    result: On status tab it tells me “initializing”. It never starts sending any SSID.
Same basic issue here. But I get a little further. I have “AP Running” but no devices can see the 5GHz network
Does the 5 GHz work on the RB4011iGS+5HacQ2HnD now with beta v2?
Now with v7 Beta 3 is the WiFi working on the RB4011iGS+5HacQ2HnD-IN
  1. routeros-7.0beta3
  MMM      MMM       KKK                          TTTTTTTTTTT      KKK
  MMMM    MMMM       KKK                          TTTTTTTTTTT      KKK
  MMM MMMM MMM  III  KKK  KKK  RRRRRR     OOOOOO      TTT     III  KKK  KKK
  MMM  MM  MMM  III  KKKKK     RRR  RRR  OOO  OOO     TTT     III  KKKKK
  MMM      MMM  III  KKK KKK   RRRRRR    OOO  OOO     TTT     III  KKK KKK
  MMM      MMM  III  KKK  KKK  RRR  RRR   OOOOOO      TTT     III  KKK  KKK
  MikroTik RouterOS 7.0beta3 (c) 1999-2019       http://www.mikrotik.com/
[?]             Gives the list of available commands
command [?]     Gives help on the command and list of arguments
[Tab]           Completes the command/word. If the input is ambiguous,
                a second [Tab] gives possible options
/               Move up to base level
..              Move up one level
/command        Use command at the base level
[XXXXXXXX@MikroTik] > /export hide-sensitive
# oct/31/2019 14:10:02 by RouterOS 7.0beta3
# software id = YPJS-5AHL
# model = RB4011iGS+5HacQ2HnD
# serial number = B8E20ADDB8AD
add arp=reply-only name=Guest_Bridge
add admin-mac=74:4D:28:XX:XX:XX auto-mac=no comment=defconf name=bridge
/interface wireless
set [ find default-name=wlan2 ] antenna-gain=3 band=2ghz-onlyn channel-width=20/40mhz-XX country="united kingdom" disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain installation=indoor mode=ap-bridge name=2.4Ghz ssid=\
    Net_2 wireless-protocol=802.11 wps-mode=disabled
set [ find default-name=wlan1 ] antenna-gain=3 band=5ghz-n/ac channel-width=20/40/80mhz-Ceee country="united kingdom" disabled=no distance=indoors frequency=auto frequency-mode=regulatory-domain installation=indoor mode=ap-bridge name=5Ghz \
    secondary-channel=auto ssid=Net_5 wireless-protocol=802.11 wps-mode=disabled
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] authentication-types=wpa-psk,wpa2-psk mode=dynamic-keys supplicant-identity=MikroTik
add authentication-types=wpa2-psk eap-methods="" mode=dynamic-keys name=Guests supplicant-identity=MikroTik
/interface wireless
add default-forwarding=no disabled=no mac-address=76:4D:28:XX:XX:XX master-interface=2.4Ghz name=2.4Ghz_Guests security-profile=Guests ssid=Net_G wps-mode=disabled
add default-forwarding=no disabled=no mac-address=76:4D:28:XX:XX:XX master-interface=5Ghz name=5Ghz_Guests security-profile=Guests ssid=Net_G wps-mode=disabled
/ip ipsec mode-config
add name=NordVPN responder=no src-address-list=local
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=uk1394.nordvpn.com disabled=yes exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
add disabled=yes name=NordVPN pfs-group=none
add name=dhcp_lan ranges=192.168.10.10-192.168.10.35
add name=dhcp_guests ranges=10.1.1.2-10.1.1.25
add address-pool=dhcp_lan disabled=no interface=bridge lease-time=12h name=LAN
add add-arp=yes address-pool=dhcp_guests disabled=no interface=Guest_Bridge lease-time=12h name=Guests
/interface bridge filter
add action=drop chain=forward in-interface=5Ghz_Guests
add action=drop chain=forward out-interface=5Ghz_Guests
add action=drop chain=forward in-interface=2.4Ghz_Guests
add action=drop chain=forward out-interface=2.4Ghz_Guests
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add bridge=bridge comment=defconf interface=5Ghz
add bridge=bridge comment=defconf interface=2.4Ghz
add bridge=Guest_Bridge interface=5Ghz_Guests
add bridge=Guest_Bridge interface=2.4Ghz_Guests
add interface=Guest_Bridge list=LAN
add address=192.168.10.1/24 comment=defconf interface=bridge network=192.168.10.0
add address=10.1.1.1/24 interface=Guest_Bridge network=10.1.1.0
/ip dhcp-client
add comment=defconf dhcp-options=hostname,clientid disabled=no interface=ether1 use-peer-dns=no use-peer-ntp=no
/ip dhcp-server lease
add address=192.168.10.12 client-id=XXXXXXXXXXX comment="Nvidia Shield" mac-address=00:04:4B:XX:XX:XXX server=LAN
add address=192.168.10.101 client-id=XXXXXXXXXXXX comment=Synology mac-address=00:11:32:XX:XX:XX server=LAN
add address=10.1.1.4 mac-address=XXXXXXXXXXXXXXX server=Guests
add address=10.1.1.0/24 dns-server=10.1.1.1 gateway=10.1.1.1 netmask=24
add address=192.168.10.0/24 comment=defconf dns-server=192.168.10.1 gateway=192.168.10.1 netmask=24
set allow-remote-requests=yes servers=1.1.1.1,1.0.0.1
/ip dns static
add address=192.168.10.1 comment=defconf name=router.lan
/ip firewall address-list
add address=192.168.10.0/24 list=local
add action=accept chain=input comment="defconf: accept to local loopback (for CAPsMAN)" dst-address=127.0.0.1
add action=accept chain=forward dst-address=192.168.10.101 dst-port=16881 in-interface-list=WAN protocol=tcp
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
add action=dst-nat chain=dstnat disabled=yes dst-port=8883 in-interface-list=WAN protocol=tcp to-addresses=10.1.1.4 to-ports=0
/ip ipsec identity
add auth-method=eap certificate="" disabled=yes eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN peer=NordVPN policy-template-group=NordVPN username=XXXXXXXXXXX
/ip ipsec policy
set 0 disabled=yes
add disabled=yes dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=0.0.0.0/0 template=yes
/ip service
set telnet disabled=yes
set ftp disabled=yes
set www disabled=yes
set ssh disabled=yes
set api disabled=yes
set api-ssl disabled=yes
#error exporting /ipv6/route/rule
#error exporting /routing/policy/selection
/system clock
set time-zone-name=Europe/London
/system leds
add interface=2.4Ghz leds=2.4Ghz_signal1-led,2.4Ghz_signal2-led,2.4Ghz_signal3-led,2.4Ghz_signal4-led,2.4Ghz_signal5-led type=wireless-signal-strength
add interface=2.4Ghz leds=2.4Ghz_tx-led type=interface-transmit
add interface=2.4Ghz leds=2.4Ghz_rx-led type=interface-receive
/system package update
set channel=development
/system resource irq rps
set sfp-sfpplus1 disabled=no
/tool mac-server
/tool mac-server mac-winbox
5.https://pasteboard.co/IEwBPY8.jpg, https://pasteboard.co/IEwUNW7.jpg
I’ve same problem.
Any news on 7.0b4 ???
Same problem with ros7 beta5.
I confirm no beacons are broadcast on the 5GHz radio on RB4011 with RouterOS 7b5.
i’m facing same issue with my RB4011iGS+5HacQ2HnD (noticed it after ugprade to 6.46.4.)
Have any one raised support ticket for this issue ?
If it’s not working on all firmware versions, then probably it’s a hardware issue.
Can we get a replacement from MikroTik?
Is there any official communication from MT regarding this issue ?
Any word on 7.1?
