RB4011iGS+5HacQ2HnD Password after Update.
Today, I noticed that there was an update available.
After the update, I got the message that my “winbox” is too old and no longer supported. So, I switched to a new one.
Now, I’m getting the message that my password is incorrect.
However, the router doesn’t have a password, and there’s nothing about a password on the sticker on the router either.
The manual clearly states that there is NO default password.
so how do i now connect, even a full reset dont give me a password
Just to make sure: you leave the password empty and you get the message “incorrect password”?
Did you reset by use of the reset button? Sure it is reset?
You didn’t specify a password for this device?
Last resort: netinstall:
https://help.mikrotik.com/docs/spaces/ROS/pages/24805390/Netinstall
Can you connect through console?
