kindly need help how to configure wifi on mikrotik RB4011GS model step by step
It’s already configured from the box. Just use the MikroTik app from the app store, connect to network “MikroTik” and set password in the Wizard.
i setup settings from wizard but wifi from wizard is not working properly i mean its connected properly trough wifi but the internet speed is to slow and my isp connection speed is 24 mb that is the problem which i am facing on router
No worries, I know the seemingly lost feeling you have!! - forget about wizards and quickset for now… please post your config and will see if it can be sorted out, or something more drastic done.
PS Dont mind Normis, he sleeps with MT products under his pillow and absorbs knowledge when he sleeps. He is surrounded by geeks all day long and speaks in MT code without thinking. Thus he has lost the touch to speak to mere mortals.
PPS He sounds like one of my daughters - “just use the App dad, whatdya mean you dont have the app, do you even know how to download an app…”
