RB4011iGS+ Auto Negotiation fail
Hi folks, hi have a new RB4011iGS+ with problems on ether2/3/4. On these ports auto negotiation fails, it don't matter what kind of device i connect (server, NAS, laptop, switch...etc). Link is up only at 10M half duplex.
Tried different patch cords wich works on other ports.
Firmware: 6.46.1
Log:
dec/17 16:54:37 interface,info ether2 link up (speed 10M, half duplex)
dec/17 16:54:37 interface,info ether3 link up (speed 10M, half duplex)
dec/17 16:54:37 interface,info ether4 link up (speed 10M, half duplex)
if i uncheck/check Auto Negotiation on Interface properties link is up at 1G until reboot
dec/17 16:59:00 interface,info ether2 link down
dec/17 16:59:04 interface,info ether2 link up (speed 1G, full duplex)
dec/17 16:59:11 system,info device changed by ******
dec/17 16:59:11 interface,info ether3 link down
dec/17 16:59:16 interface,info ether3 link up (speed 1G, full duplex)
dec/17 16:59:17 system,info device changed by ******
Try going back to version 6.45.7.
I’m not sure, but in my opinion there is a difference in the operation of the interfaces with v6.45 and 6.46. Let’s check.
i have been tried, same thing…
Did you try both versions? Maybe it is a hardware fault, at least for me RB4011 has no issues.
generate a supout.rif file and send it to us: https://help.mikrotik.com/servicedesk/
